FlashProManager 4.0.7
V4.0.7 (30 Mar 2023)
  • Firmware updated to version 224
  • [2022+ Civic Si] Added support for 2023 model 64B-AA1 US
  • [2014 Civic Si] Added support for 2014 model RX0-K41 Central America
  • [2022+ Civic] Added support for 2022 model 64D-S61 Indonesia
  • [2018+ Accord 1.5] Added support for 2020 model 6A0-872 US
  • [2015+ FK2 Civic Type R, 2017-2021 FK8 Civic Type R] Changed name of table 'VE correction' to 'AFM correction' to better reflect the use of the table
  • [2017-2021 FK8 Civic Type R] Added another turbo temperature limit table (2019+ only)
Download here
Please only reply to this thread with issues & questions specific to the changes in this release. For all other problems start a new thread under the appropriate vehicle category.
With the FK8 correction table change only the table name has changed. The values and function of the correction tables have not changed.
Rares
Re: FlashProManager 4.0.7
Post by Rares »
Hello, It seems that this new table is also visible in the calibrations for FK8 2018.
Is it on purpose or is it a problem?
What is its role and how should it be used, how is it different from the other table?
Thank you!
Yes, some 2018 FK8s have the additional table.
It is an another turbocharger maximum pressure ratio table based on intake temperature and rpm in order to limit the discharge temperature of the compressor.
Fkay8
Post by Fkay8 »
I have detected some issues on this version
Help > Check for updates > You can't see the versions the numbers are all overlaid.
On any FK8 calibration (I only saw this one), on the main table window > The table window list you only see to torque 4th (comfort), you can scroll down and get access to the others but before this version, when you click on the list it show every table available.
Sounds like windows screen scaling is doing something odd. What is your monitor 'scale' (eg 125%, 150%) and do you have the option is settings for 'use windows screen scaling' checked or unchecked? A screen shot might help.
Fkay8
Post by Fkay8 »
Here you have some screen shots, maybe is something in my computer I don't know but before never had this issue and I don't have changed anything.
Thanks for the quick reply
Hondata wrote: Thu Apr 06, 2023 8:24 am What is your monitor 'scale' (eg 125%, 150%)
Also Help About gives the screen DPI which might help.
Fkay8
Post by Fkay8 »
Hondata wrote: Thu Apr 06, 2023 8:40 pm
Yes you were right my screen was at 125% I changed to 100% now all the things are perfect.
Thanks for the help
V4.0.8 has improvements with screen scaling over 100%
