K24a EP3
tlikethedrink
K24a EP3
I just finished my k24a swap in my 2005 EP3.
I’m currently running a:
Jdm k24a RBB-3
PLM Header with 2.5 out
2.5 Exhaust with a Vibrant Muffler
HPS intake (2.5 diameter i believe)
Stock RBB Intake Manifold with TB adapter
Stock 25* Cam gear
Stock 310cc injectors
Stock oil pump
Kpro v4
Currently running the TSX Base tune as I continue to clean up and zero in on minor non mechanical issues while breaking in the clutch.
I have questions regarding upgrades after break in or tuning as is…
1) I’m skeptical of the RBB intake to a3 TB and intake set up. I’m weighing out a Skunk 2 rep intake manifold ported and polished out. This would give me more hood clearance and open the door for 3-3.5 intake options. I would like to keep the factory TB functions so keep the stock TB if needed.
2) the RBC cam gear from the A3 is still laying around. I would like to run it with a new intake set up. OR should I wait for possibly cams in the future. I also have the PRB IM to use and port if needed.
Question is, is it worth it to do #1 without #2? Understanding they would be need to be tuned together. Also understanding that the exhaust is the new choke point.
I would love to hit 230 or even gasp 240 hp on pump. Similar set ups seem like a simple recipe of: RBC, 50*, 3.5 intake and 3” exhaust.
My goal is to spend (if I have to) a little extra to utilize kpro and the engine to its potential. Also to keep oe reliability.
All input welcome
Jdm k24a RBB-3
Stock 25* Cam gear
Stock oil pump
Kpro v4
All input welcome
- CalibratEd
- Contact:
Re: K24a EP3
Welcome to the forum,
If you plan to run an RBC intake or aftermarket the 50 degree VTC is needed to make sure you get the power from the intake. These intakes also shift the power band up as well.
-Ed
-Ed
Instagram: calibrated.tuning
tlikethedrink
Re: K24a EP3
Thanks for the reply and welcome!
I have the 50*, and will probably stock like a tb/im for later down the road.
For now, I’ve started running the 91 octane tsx map. Is there another map I can use to take more advantage of my bolt ons for now?
- CalibratEd
- Contact:
Re: K24a EP3
To take full advantage you would need a custom tune. For now I suggest you make sure the fuel and timing are dialed in on the calibration file you are using. The car will not run as well as it should.
-Ed
-Ed
tlikethedrink
Re: K24a EP3
Thanks Ed.
I’ll do some data logs, any pointers?
- CalibratEd
- Contact:
Re: K24a EP3
Make sure the fuel trims are +-5 and reduce timing where you see knock.
-Ed
-Ed
MondeCruel
Re: K24a EP3
Tune your fuel maps one by one (0.10.20.30.40.50) low-speed and high speed, and use the display fuel adjustement values (shift+f5) to get them close to 0%. Also to have good data to work with be gentle with the gas pedal and seek at least 20-30 samples to make adjustement.
tlikethedrink
Re: K24a EP3
I may have overstated my experience with tuning lol. I had kpro like 10 years ago and uploaded a JRSC tune to my k20a3.
That’s about the extent of my experience. This time around I’ve uploaded the tune, messed with the basic immobilizer and bad settings.
I would love to learn though. Anyone patient enough to coach?
- CalibratEd
- Contact:
Re: K24a EP3
I suggest you look at Evans tuning videos on youtube. He has many videos on kpro. You are also welcome to post your questions here and I can help you.
-Ed
-Ed
captainnemo12
Re: K24a EP3
Does anyone have etuned base map for 2005 civic si ep3
Parts
Jdm k24a rbb3
50 degree vtc gear
Type s oil pump
Injen cold air intake
Thank you 🙏
Parts
Jdm k24a rbb3
50 degree vtc gear
Type s oil pump
Thank you 🙏
- CalibratEd
- Contact:
Re: K24a EP3
You can start with a stock k24 base map and adjust accordingly or try this one. viewtopic.php?t=25430captainnemo12 wrote: Sat Apr 15, 2023 9:13 pm Does anyone have etuned base map for 2005 civic si ep3
Parts
Jdm k24a rbb3
50 degree vtc gear
Type s oil pump
Thank you 🙏
Remember no two cars are the same so adjustments will be needed.
-Ed
captainnemo12
Re: K24a EP3
Copy. ill try all of that and i replace my injector to rdx 410! idk if is gonna effect on that tune! thank you ed
- CalibratEd
- Contact:
Re: K24a EP3
Yes it will have an effect on the tune. Make sure to place close attention to your fuel.captainnemo12 wrote: Fri Apr 28, 2023 8:04 pm Copy. ill try all of that and i replace my injector to rdx 410! idk if is gonna effect on that tune! thank you ed
-Ed
captainnemo12
Re: K24a EP3
Can i send a data log in pm while im doing it ? Thank you
- CalibratEd
- Contact:
Re: K24a EP3
You can start your own thread and post the datalogs there.captainnemo12 wrote: Fri Apr 28, 2023 9:05 pm Can i send a data log in pm while im doing it ? Thank you
-Ed
