KMiata Kpro low voltage & misfires
Posted: Sun Mar 12, 2023 10:50 am
Hello, I have a recently built K24A swapped miata running KPro v4, which is misfiring at high rpm and load. It initially ran fine and started sporadically misfiring at high rpms, but now it does it all the time when pushed. If I persist it throws a P0336 fault code (crankshaft position sensor). I tried changing that with a spare but the problem remains. On throttle I noticed that the BAT voltage on KPro drops significantly, as low as 10-11V, so I assume the problem is there.
The actual battery voltage does not drop, as it stays around 13-14V in all driving conditions when measured with a multimeter. All grounds have been checked, coils and battery have been swapped. I have attached some log files. Any advice would be appreciated.
John
John
