S300 Wideband Setup
Men
S300 Wideband Setup
Post by Men »
I have a obd2 engine harness with a obd1 jumper connected to a p06 with an s300. I was wondering if I tap in to the jumper harness cable which would lead to pin d14, if that isn’t right should I tap into somewhere on the harness or should I go about tapping into a different pin like D10 which I do not really get
Re: S300 Wideband Setup
You should not tap into any wires, as that may cause them to break. You should de-pin them from the harness and then run wires into those inputs so that it can be undone if it needs to be. You should not use D14 as it cannot see the full voltage range. D10 would be a better input to use: http://www.hondata.com/help/smanager/wi ... b=wideband
There is a list of the pins and locations at: http://www.hondata.com/help/smanager/ecuconnectors.htm
