Reverse Lockout
Herzog123
Reverse Lockout
Post by Herzog123 »
I'm totally new to this.
I’m doing a K24A2 swap into an EP3 Civic. I have a new KPro installed on the Civic’s PNF ECU. I wanted to know how I can program reverse lockout to activate on my six speed transmission. Current wiring harness is the EP3 civic. I've read that the intake runner plug controls the reverse lockout. Will this work in my setup? I have also read that I should be using the PRB map in Kpro, but don't I want a different map for the K24A2?
Re: Reverse Lockout
This will not work on a PNF ECU as it does not have the circuitry for this.
Herzog123
Re: Reverse Lockout
Post by Herzog123 »
Thanks for getting back to me so quickly. Will the solution in the following link work? Can you confirm. No relay is needed. https://humbleperformance.freshdesk.com ... -kpro-ecus
Re: Reverse Lockout
You can try it, but is not recommended by us.
