2013 si basemaps
whitesiyo
2013 si basemaps
Post by whitesiyo »
here are some data logs with a few pulls i did. can you tell me if im lean or rich im trying to understand how to adjust these numbers
CalibratEd
Re: 2013 si basemaps
Post by CalibratEd »
I saw that you have made multiple threads. I suggest you stick to one and update it. Its easier to get your questions answered in one place.
"I could really use some help with. also do you mind walking me through some of your work so i can understand what your changes and what you see that are discrepancies. I would like to understand what youre looking at and how to navigate and better understand the hondata program."
In order to better understand changes I suggest you gain some basic knowledge of tuning. Check out Evans tuning or Huntertuned on youtube. I also suggest looking into Books by Greg Banish to learn the theory. Once you have basic theory you can then get familiar with the software.
To have someone review your datalogs post the calibration file as well.
-Ed
Instagram: calibrated.tuning
whitesiyo
Post by whitesiyo »
thanks for the response ed. i have posted multiple times only becuase i have had no responses from anyone. i know huntertuned very knowledgeable guy. ive watched videos im just nervous to start moving things around. and as far as the calibration its the MAF basemap.
CalibratEd
whitesiyo wrote: Wed Jan 25, 2023 6:57 pm thanks for the response ed. i have posted multiple times only becuase i have had no responses from anyone. i know huntertuned very knowledgeable guy. ive watched videos im just nervous to start moving things around. and as far as the calibration its the MAF basemap.
This forum is a bit slow but I try to help out when I am not swamped with work. If you want to learn to tune you need to start with small adjustments. MAF tuning and MAP tuning are different. I tend to lean toward MAP tuning.
-Ed
whitesiyo
Post by whitesiyo »
so i uploaded the MAF tune. i have a takenda intake. i thought running that basemap would be best but idk. i do seem to be a bit laggy when vtec kicks in.
CalibratEd
whitesiyo wrote: Wed Mar 15, 2023 5:31 pm so i uploaded the MAF tune. i have a takenda intake. i thought running that basemap would be best but idk. i do seem to be a bit laggy when vtec kicks in.
I would stick to a MAP based tune.
-Ed
