S300 cranks no start
Posted: Mon Jan 16, 2023 2:56 pm
by Jbrracer
s300 in p28 ecu.
smanager shows online does datalog, uploads and downloads correctly.
using the "b20 non vtec" base tune.
Car is b swapped hatch with b20b non vtec head.
car will run on p75 ecu fine.
What am I missing
Thank you!
Jeff
Re: S300 cranks no start
Posted: Mon Jan 16, 2023 3:38 pm
Is there fuel and spark?
Posted: Mon Jan 16, 2023 3:45 pm
by Jbrracer
fuel pump primes no spark
thanks
Posted: Mon Jan 16, 2023 4:08 pm
You need to try the ECU on a known working vehicle and see if it starts and runs with the calibration for that vehicle. If it does not, then the ECU may be bad.
Posted: Mon Jan 16, 2023 5:43 pm
by Jbrracer
I will try that, it wouldn’t matter that it’s a non vtec motor and harness correct?
Posted: Tue Jan 17, 2023 10:44 am
It should not matter for just starting it up as long as the calibration loaded is close to the vehicle you are testing in.
Posted: Wed Feb 01, 2023 7:53 am
by Jbrracer
hey spunkster
I socketed a p75 and it did start.
I'm suspecting a faulty ecu. any thoughts on what i could try on this bad one before switching to the p75?
Thank you a ton
Jeff
Posted: Wed Feb 01, 2023 10:04 am
You can try replacing the capacitors, but that may not solve anything.
https://www.hondata.com/products/access ... acitor-kit
It's usually more costly and takes more time than it is worth to try and repair a damaged ECU. It is better to just get a working ECU instead.
Posted: Wed Feb 01, 2023 2:39 pm
by Jbrracer
I have a set on hand ill give it a shot
