Boost Controller Not Responding
EGAJohn
Post by EGAJohn »
Today I just finished installing the boost controller on my second Integra and set it up exactly how my race car is. I was going to install the ecu circuitry myself but noticed someone installed the components already. When I tested the output in the online tab it worked and was responding to my duty & frequency changes. I set up my low/ high boost maps and hit the road. I tried both low and high boost and neither got a response from the boost controller. I was just at wastegate pressure the entire time. I pulled over and tried setting a fixed duty cycle and still no response. Last thing I tried was changing the frequency to 33hz. Still nothing. But when I got back and tried the test output function it still works. Never had this happen before so I'm not sure where to begin.
TTR
Re: Boost Controller Not Responding
Post by TTR »
The boost control is set to target duty cycle. If you look in the high boost table its set to 25, which is 25%. The lookup table is only 4.9 psi at 25% duty.
Post a datalog showing the issue.
Your boost (low/default) table is all 0's.
EGAJohn
Post by EGAJohn »
Regardless of the lookup tables and boost by gear tables I tried fixed duty cycle at different percentages and still got no response. It's currently back on boost by gear even though it's not working. I want low boost to be 0% and I'll dial in high boost once it's working. I did confirm the low/ high boost SCS input is working. I'll record a datalog when I get home to see if it's giving any wg demand. Maybe I need to try a higher duty cycle? On my racecar I have 15% - 80% usable range on the boost controller.
