Kpro sensor reading wrong
chuck mangione
Post by chuck mangione »
Having an weird issue with krpo showing wrong sensor readings on a laptop and datalogs. Ignition, battery voltage, gear, and wideband says off, maybe some other sensors. Everythng reads fine on the bluetooth hondata app though.
The car had been sitting for 6-7 months now and just got it running. ECU had been sitting inside connected the entire time (inside garage), but car battery was removed.
Car off ign on, or car running, it still reads wrong. It uploads fine no error codes or cel. Car still starts and runs fine. Tried uploading different maps, using different cables, different laptops. Everything was working fine before.
Re: Kpro sensor reading wrong
What is the serial number on the K-Pro board inside the ECU?
chuck mangione
It is version 4.5.3.0. krpo v4 49886
Have you uploaded your calibration to the ECU using the new software?
chuck mangione
Yeah I have. It says upload successful every time. Tried using the rsx stock equivalent calibration also.
Post your calibration as well as a datalog made using that calibration.
