Data Logging Stop
Posted: Sun Nov 27, 2022 6:45 pm
Hi guys,
My s300 will connect to my laptop but when I go to data log (lightning bolt) it will only log for a few seconds then stop. Then after that it won't log at all. I originally thought this was a grounding issue as this has been on and off for weeks now since installing the s300 into another ECU. I realized my ground from the valve cover was disconnected and after reconnecting it I was able to data log for a few hours until it stopped again (longest it's ever logged). Multiple things have allowed me to log for a brief amount of time at random, like cleaning the ecu with alcohol, re-seating the hondata, and randomly after restarting laptops and the car. I'm running NGK iridium plugs and NGK spark plug wires. The car is boosted (~5-7 psi now) and is running on a street tune that me and my friend were able to scramble together in the times where hondata has been data logging. I've tried a different laptop, disconnecting my gauges, cleaning my grounds (battery, transmission, valve cover, thermostat), cleaned the ecu, and changed plugs and wires. Still nothing has given a real solution. As far as I know my distributor is stock and also something to note my radiator fan was jumped for a long time as I think my thermostat isn't working. If their is any thing I can provide to help please just ask and I'll try to provide it.
Thanks,
Johnny
Thanks,
Johnny
