Inches values are scattered all over the place
Posted: Tue Nov 15, 2022 6:45 pm
by Ichiro718
So if y'all would take a look at my inches table, you'll see how it starts off at -3.8" then it increases well into mid load section up to -28.7" then it goes to 0.4 which i assume is boost psi. I was under the assumption that vacuum decreases as rpm build then boost comes adding positive pressure, which would mean the numbers would start off at -28.7 then work it's way down to -3.8 then go to boost... Why is the inches table numbered like that?(i know i can change the index) what do yours look like?can i take these same numbers and just reorder them?
Re: Inches values are scattered all over the place
Posted: Tue Nov 15, 2022 8:51 pm
by Ichiro718
The numbers towards the right, after the .04, that's boost psi correct?
Posted: Wed Nov 16, 2022 10:04 am
Go to Options, Settings and then change the units as in the image
Posted: Wed Nov 16, 2022 3:48 pm
by Ichiro718
Mine is already like that. I'm talking about how the values for inches aren't decreasing in order, but are just random
Posted: Wed Nov 16, 2022 4:16 pm
Post your settings
Posted: Wed Nov 16, 2022 5:07 pm
by Ichiro718
It appears i didn't have it set up correctly. Everything is fine now. You have been most helpful, thank you!
