I am currently awaiting a new timing chain kit to fix my FG2. I have a basemap tune on her right now, currently running the one for skunk2 I/H/E with stage 1 cams. Come to find out, when I go to do my valve lash adjustment and check the cams (due to my datalogs showing some knock and IGN timing being too advanced) these things are NOT aftermarket stage 1 cams like I (and previous owner) was told - they’re stock, and miserably out of time with the crankshaft. To which I thought, “awesome.”
*NOT TO MENTION: The cam collar/lock/whatever you want to call them, there were like 7 loose bolts.. what. Probably accounts for the knock/weird angles/etc. Also maybe accounts for the chain teeth jump, but at 170k mi., I assume it’s the OEM tensioner/stretched chain, so as long as I got her broke down this far I might as well replace it.
So when I complete this tedious job that was to just be a lash adjustment, should I choose a different basemap to run on the stock cams? Or should I keep it and adjust cam degree/IGN/etc. through the flashpro?
As far as I can see, everything inside the engine head is stock. Fuel injectors are stock 310cc, valve springs are stock, I also assume everything is original OEM - though they were inside to at least replace the valve cover gasket seal because that was a replacement.
Aftermarket CAI, wide bore TB, intake man., headers, cutback. All skunk2 except the TB.
Next week after the repair and button up Ill post datalogs.
Timing issues, basemap change?
brapam3K20
Return to “Civic Si 2006-2011 Americas”
Jump to
- General
- ↳ Hondata News
- ↳ Applications
- ↳ Non-Hondata
- s100/s200/s300
- ↳ s300 / SManager
- ↳ S300 Calibrations
- ↳ SManager Display Templates
- ↳ s100/s200
- ↳ Romeditor 4 Software
- ↳ HondaLogger Software
- ↳ Coil Pack Retrofit
- K-Series
- ↳ K-Pro / KManager
- ↳ K-Pro Calibrations
- ↳ KManager Display Templates
- ↳ K-Series Reflash
- FlashPro
- ↳ FlashPro Manager
- ↳ FlashPro Calibrations
- ↳ Accord 2008+ FlashPro
- ↳ Civic Si 2006-2011 Americas
- ↳ Civic Si 2012-2015 US/Canadian / 2013+ ILX
- ↳ Civic Type R 2006-2010 Japanese FD2
- ↳ Civic Type R 2007-2011 European FN2
- ↳ Civic Type R 2015+
- ↳ Civic 2016+ 1.5 Turbo Americas/Asia
- ↳ CRV 2017+
- ↳ CR-Z 2010-2012 US/Europe/Asia
- ↳ Fit 2007-2008
- ↳ RDX 2007-2012
- ↳ S2000 2006-2009 Americas/Europe/Asia
- ↳ TL 2007-2008
- ↳ TSX 2004-2014
- Traction Control
- ↳ General / Traction Control Manager Software
- ↳ Traction Control with S300
- ↳ Traction Control with KPro
- ↳ Traction Control with FlashPro
- Bluetooth Mobile Apps
- ↳ Hondata Mobile
