Map sensor options greyed out
Hello everyone, so i downloaded s300 last night and I'm trying to input my data for the map sensor, but it's giving me issues. I have a Burton racing 3 bar map sensor(are they any good?) And I input the scalar data and the offset data with no problem. Issue is that i can't change the "mbar@5v" value because it's greyed out. The value isn't matching up to the info I'm supposed to input. Can I get some assistance? I purchased the hondata but i didn't receive it yet.
Re: Map sensor options greyed out
I uploaded a picture of the screen. The value I'm supposed to have at mbar@5v is 3180.
The greyed out parts are calculated fields. You should change the scalar and offset. In any case 3180 is only 1.5%.
So there isn't a way of changing that even once I'm connected to the ecu? It's my first time and I'm trying to get everything perfect.Hondata wrote: Sun Oct 23, 2022 11:07 am The greyed out parts are calculated fields. You should change the scalar and offset. In any case 3180 is only 1.5%.
They are calculated from the scalar and offset. eg 5v x 677 - 155 = 3230
I think you entered 677 rather than 667 for the scalar.
You know, that's a high probability😆 will report back. Thanks
I'm so silly😆i did have 677 lolol
