Bought new PCM for my FK8
LexieGrayRose_FK8
Post by LexieGrayRose_FK8 »
Hello Hondata,
I had an internal issue with my ecu and needed to order a new ecu for my FK8.
After programming new ecu to vehicle, I tried to flash it with my flashpro, but it would not work.
Do I need to jailbreak this new ecu, even though it has my vehicles vin number?
I noticed the new ecu Honda sent was an updated Bosch part number compared to my 2019 Fk8 older ecu
Re: Bought new PCM for my FK8
Did you return the original ECU to stock and unlock the FlashPro from it?
The new ECU will have to be jailbroken to be able to use it as well.
What is the ECU part number?
LexieGrayRose_FK8
Spunkster wrote: Tue Oct 18, 2022 10:54 am Did you return the original ECU to stock and unlock the FlashPro from it?
I did not return to stock and unlock it from the original stock ecu.
Will do that and report back, Thanks.
The new ecu part# 37820-5BF-A23
Old ecu # 37820-5BF-A21
That ECU part number is supported.
LexieGrayRose_FK8
Great , Thanks. Will follow those steps and try again.
