K-Pro not recognizing ignition
Posted: Sun Oct 16, 2022 4:21 pm
by austin444
I was driving on the highway a couple days ago, shifted into 5th gear and the car started sputtering as if it wasn't getting fuel. I ended up having to get it towed back home only to find out the fuel pump was no longer kicking on when turning the key over. This is a k24 swapped 2004 rsx Type-s and was driving good for a week prior to this happening. Help!!
Re: K-Pro not recognizing ignition
Posted: Mon Oct 17, 2022 9:25 am
You should try the ECU on a known working vehicle and see if it works as it should. If it does then there is most likely an issue with the wiring in your vehicle that needs to be addressed.
