Changing Parameters for Tables?
7plymaple
Post by 7plymaple »
Hi all,
I would like to make a map with a rev limit raised by about 500rpm. I can go into calibration and raise the limiter but my tables only go up to 7000 and my stock rev limiter is 6800 so I'd like to get up to 7300rpm.
Can change the parameters of my tables?
What happens if I raise the limiter above 7000rpm right now? Does it keep the values from 7000rpm up?
Re: Changing Parameters for Tables?
It will not change anything as it reads from the last value on the table.
7plymaple
Post by 7plymaple »
Thanks good to know. So I guess I can datalog and see what's happening to set a last value that works for the few hundred RPM's I'm going over? I will be testing this out tomorrow.
Is there a way for me to change the tables so they go higher?
What vehicle are you referring to?
7plymaple
Post by 7plymaple »
Its a 2015 civic lx
You should not have to make any changes to the indexing of the table as it will use the last value in the table at the RPMs past 6800.
7plymaple
Post by 7plymaple »
Yeah I seem to be getting good results on the datalogs. Thank you!
