Did firmware update and now the engine goes lean
Posted: Fri Oct 07, 2022 4:30 pm
by brad3874
I was having my car tuned the other day and just about had everything dialed in, we were about to make a couple last small changes and a message popped up telling us to update the firmware. So we did but after the update completed the engine would go super lean under any engine load. No mater how much fuel you added it will not have an effect on my afrs. All my sensor inputs seem to be reading correctly. The car ran perfectly before the firmware update. Fuel pressure is fine, has a new fuel pump, ,injectors, and filter. Any ideas?
Re: Did firmware update and now the engine goes lean
Posted: Fri Oct 07, 2022 4:35 pm
Post a picture of the s300
Posted: Fri Oct 07, 2022 4:47 pm
by brad3874
Posted: Fri Oct 07, 2022 5:02 pm
Posted: Fri Oct 07, 2022 5:29 pm
by brad3874
Okay I sent it.
