FK8 misfiring?
Posted: Mon Oct 03, 2022 3:49 am
by leechihfei
Hi Hondata,
I have been feeling what seems to be mis-firing issues.
My FK8 is a 2018, with G25-660 turbo, PRL exhaust, Cat back exhaust, PRL intercooler, Radiator upgrade, Hondata Fuel upgrade, etc.
After tuning and running around is fine. But I noticed mis-firing occasionally, around 5500rpm especially on a hot day (32 deg C) on track. Changed the plugs, to no avail. Looked at the data log, can't quite make sense of it.
Mis-firing, meaning like it feels like a power cut, unable to generate bhp, burbles from exhaust.
Attached datalog for your kind assistance and analysis.
Re: FK8 misfiring?
Posted: Tue Oct 04, 2022 6:09 am
Your fuel trims are high, but the problem is that the fuel system is losing fuel pressure over 5000 rpm.
Re: FK8 misfiring?
Posted: Thu Oct 06, 2022 1:44 pm
by leechihfei
If I've already have Hondata Fuel upgrade, and I'm losing fuel pressure, what could be the problem?
1. Fuel filter?
2. As everything else is supplied by Hondata Fuel Upgrade System. Did I miss any other possible (culprit) part?
Re: FK8 misfiring?
Posted: Thu Oct 06, 2022 1:56 pm
Have you checked the fuel system for contamination?
Please see:
https://www.civicx.com/forum/threads/us ... ion.65283/
Re: FK8 misfiring?
Posted: Sun Oct 09, 2022 1:00 pm
by leechihfei
No I haven't. I'm not on flex fuel.
Regardless, will revert upon doing so.
Re: FK8 misfiring?
Posted: Tue Aug 22, 2023 12:08 am
by leechihfei
Hi,
Since your suggestion to check the fuel filter, I had it changed.
Did notice that there were some contaminants - but not surprising since my car has pushed past 30,000 miles already.
Change to a new fuel filter and a new low pressure fuel pump.
Re-tuned the car with 4Pistons cams on a dyno. It was great. On the Dyno, it was fine, 20 out of 20 pulls.
_________________________________________________________
BUT after driving for about 1000 miles, and 100 miles that day, the same backfire problem started again. Log attached.
I must stress the problem is intermittent - 5 out of 10 pulls on the road, I get the backfire. But it can be replicated when I get it.
a. Could the Hondata Hi Pressure Fuel Pump be acting up?
b. Heat? (Ambient was about 90 degF)
Re: FK8 misfiring?
Posted: Tue Aug 22, 2023 9:06 am
It looks like the fuel system is maxing out. You may need to try lowering the air charge to make less boost so that it does not max out.
Re: FK8 misfiring?
Posted: Wed Aug 23, 2023 3:33 am
by leechihfei
1. When I look at the datalog. I notice that the Fuel Pressure dropping first, BEFORE the Fuel Pump Duty Cycle hits 100%.
Doesn't this indicate the High Pressure Fuel Pump is having a problem?
2. And AirC is at 224% Is that even high?
3. Also, the backfire doesn't happen all the time. I have some logs that allows a clean pull, using the same calibrations.
Re: FK8 misfiring?
Posted: Fri Aug 25, 2023 10:19 am
What is your fuel system serial number?
Re: FK8 misfiring?
Posted: Sat Aug 26, 2023 5:51 am
by leechihfei
My fuel system serial number is 1034.
Re: FK8 misfiring?
Posted: Mon Aug 28, 2023 8:55 am
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread
