MAP not reading on app
SFTifoso
Post by SFTifoso »
The MAP reading reads zero, when using the stock factory calibration. But it datalogs the stock map reading just fine. Is there a way to make the app display MAP with the factory calibration?
Re: MAP not reading on app
What Hondata system and vehicle are you referring to?
SFTifoso
Post by SFTifoso »
2010 civic si
CARB flashpro
It will only read correctly if you have uploaded a Hondata calibration to the ECU. If returned to stock it will not work.
