Built b16a turbo map help
tylerfernie
Post by tylerfernie »
Hello, looking for any tips or adjustments needed to make on the map. Very new to this
p28 s300 v3
comp cams
je pistons
comp springs
ferrare retainers & valves
aem fuel rail & regulator
aem 340 fuel pump
t3 turbo
440cc injectors
block girdle
gude oversized throttle body
arp head studs
DaX
Re: Built b16a turbo map help
Post by DaX »
We don't have enough info to help you out. You really should take it to a tuner and have them work on it for you. Or, make a datalog and post it and the calibration here and we *might* be able to give some general suggestions, but nothing will beat having an actual tuner with the car in front of them.
