[NA] 2015 Honda Civic SI FG4 k24a2: UPDATE!
dtkktd
Post by dtkktd »
Last Seen: Fri Feb 25, 2022 12:03 pm
Today: Sun Sep 18, 2022 11:59pm
_____
"INTRODUCTION:"
Hello Hello fellow Tunerz, I'm Kenichi[22] and reside in SoCal (Southern California), and have been a Honda fanatic for years!
I've owned some powerful Hondas that have been dialed in by dyno and modified to the teeth, but always with the guidance from my uncle since they were his cars. Since his passing I've taken up the idea of tuning myself- I understand the basic concepts of tuning and have been tuning my recent Honda as of 2019.
My Car:
[NA] 2015 Honda Civic Si FG4 K24a2
Backstory: Going back to the end of 2021 in December...It was a really terrible week of rain that soaked SoCal Christmas week. I knew that I shouldn't have taken the car out for a drive but did anyways because...Why not? Anyways, what ends up happening is I blow my engine because she ended up sucking up water form a lake that I drove through; not actually but you guys can imagine a terrible dip that was flooded cause of rain water). Flash forward to February with an entirely new engine.
_____
~It's been nearly several months since my last request for a Tune. On the previous episode, I was provided a Speed Density [SD] Tune and learnt some things from EFICU! There's been much trial and error along with life events that I couldn't account for, but without further ago....here is an update along with some notices with my k24a2. LET'S DO THIS!!! Also note that if I don't have a particular modification field listed, it probably means that it's not modified/stock part.
-GOAL: FBO ---> NITROUS or TURBO
Modifications:
" * " = New Mod
" A - D " = Wear/Damage on Part
Engine [swapped February 2022]-
ECU:
.HONDATA Flashpro
>Speed Density Tune
ELECTRICAL:
*A. Larger Capacity Battery
>AGM
INTAKE:
C.Injen CAI [Might swap for Weapon-R SRi w/ Dragon Filter ;) ]
*A.afe Throttle Body Spacer
TRANSMISSION:
*A.Sirimoto Clutch Master Cylinder & Slave Master Cylinder w/ Clutch Line
*A.Acuity Shifter Bushings
*A.Acuity Short Shifter
*B.K-Tuned Shift Knob
BRAKES:
B.R1 Concept Slotted and Drilled Rotors
>Metal-Alloy Brake Pads
EXHAUST
*A.PLM High-Flow Cat exhaust [Single Piece.Bolted]
B.Modified Midpipe
>Stock Resonator [Bolted]
>Vibrant Resonator [Welded]
C.Skunk2 Axleback [Bolted}
SUSPENSION:
B.BC Racing Coilovers
C.Zenas Rims [Size R18 x 8.5//Offset: 30mm//5x114.3]
>Federal Tires [245/35z R18
COSMETICS [Notable Ones]:
*A.Mugen Carbon Fiber 'Si' Badge
>Imported from Japan
>Front Grille
*B.Tri-Color LED Headlights
>W,Y,B,R
B.Seibon Carbon Fiber Hood
>V-Style
*B.IKON Motorsports PU Kit
>HFP V1.
*C.Carbon Fiber Interior Overlays
>Red/Black
D.3d Printed Ebay Wing:
>Customized Fiberglass Endplates
>Dragon Concept Style
_____
ISSUE:
I would like to ask for assistance in Tuning my Vehicle- Thank You in Advance to anyone that is willing to help!
P.S.-Datalogs OTW
支援をありがとうございました!!!
私の決意は提供されます
Kenichi Dang
dtkktd
Re: [NA] 2015 Honda Civic SI FG4 k24a2: UPDATE!
Post by dtkktd »
Data Log Comment
支援をありがとうございました!!!
私の決意は提供されます
Kenichi Dang
dtkktd
Post by dtkktd »
Datalog Comment Pt 2.
支援をありがとうございました!!!
私の決意は提供されます
Kenichi Dang
