How good works stock Knock sensor for fully build K24?
FlashPro questions & answers specific to the 2008+ Accord, Americas and international
EFhatch
Post by EFhatch »
Hi! Im tuning an K24a3 fully build All motor setup, problem im having is im getting big knock count, check spark plugs, looks soo clean all, it's just at 22 degree advance, tried to retart up to 15 degree and almost same knock count, not make sense, looks like once it's slighly modified as intake,etc, oem knock sensor will not works properly? maybe to much noise? tried to play a bit with knock sensitivy tables but looks dont apply very well changes. attaching a log as example of last pulls.
EFhatch
Re: How good works stock Knock sensor for fully build K24?
Post by EFhatch »
Thanks! lol
well i installed a external knock sensor, was a lot of noise, played a bit with sensitive for to keep it "working" but stock knock sensor when you install a bigger cams, or overbore pistons,etc. will not works properly. FYI! Cheers!
