Map sensor problems K24A2
mighty max
Post by mighty max »
Hello, im having issues with my map sensor not working believe the pins are in the wrong spot,
ECU: 37820-ppa-a67 (2003 Auto crv)
KPRO4: 58271
ENGINE: K24A2 JDM
HARNESS: RSX BASE 2002-2004, KPOWER INDUSTIRES HARNESSS RSX 02-04
The issues i'm having is map sensor not working on either harness everything else works as should tps responds correctly, idles only off of IACV,
I've been told i may have to re pin the map sensor to how the crv is pinned out ? and if I try swapping plugs tps in map plug and then i see it working but of course runs like crap and super rich. any help is appreciated only thing keeping me from driving. i have continuity to all three wires end to end.
The build is a 1987 Mitsubishi Mighty Max mini pickup truck with a jdm k24a2, honda s2000 ap1 gear box, ap1 intake mainfold,
Re: Map sensor problems K24A2
If you plug a map sensor in with it wired incorrectly it will damage it instantly and you will have to replace the MAP sensor. You must have it wired correctly before you replace it.
