K24 turbo basemap need help
Hello everyone, putting the finishing touches on my eg hatch and need a base map to get it running to check for leaks. Basic setup k24a longblock 3 lobe with type s oil pump and *50 vtc. Turbo is gtx3576r with dual 44mm Wastegates set at 7 psi, 1650cc fid injectors, mac 3 port installed and wired into b21, ethanol sensor installed but currently only 93 octane in the tank, aem 3.5 bar map sensor, aem x series wideband 30-0300 wired into Kpro. No iacv. Attached is deadtimes for the injectors. Any and all help is appreciated. 02 crv 5 speed trans with vss.
