Kpro v4 - Ignition Off, Car will turn over
Posted: Thu Sep 01, 2022 11:02 am
what vehicle you have?
‘93 CX K20Z3 swap
- serial number of your K-Pro
My serial Number is 59937
- version of software being used
I have the Version 4.4.9.0
- ECU part number (starts with 37820) and serial number (the number under the part number)
The ECU part number is 37820-PRB-A05
Trying to use PRB K20Z ‘06 RSX Type-S from the vault
No data
- anything about the car which has been modified from stock which may affect the ECU (don't include what sort of rims you have nor stereo etc).
K20Z3 swap, rywire engine harness, chassis adapter
- when and where you got the K-Pro?
Last year HAMotorsports
Turn the key, cluster lights up, starter cranks, fuel pump does not prime
KManager says Driver Installed, On Line, Ignition Off
All fuses under hood are good. I have a good battery. I have power to fuse panel, starter, alternator.
‘93 CX K20Z3 swap
No data
