Basemap for k24a7, k20a2 head and z3 cams
Posted: Sat Aug 27, 2022 1:11 pm
by kringles
is anyone able to make me a basemap for my 02 rsx with a k24z7 block with a k20a2 head and z3 cams. I am new to this whole tuning thing and was wondering if someone could get me started. its also got no cat if that helps. where i live the elevation is 3,428 ft or 1045 meters. finally i just need something that i can use so i can auto tune it.
02 rsx:
K pro V4
k24z7 block
k20a2 head
k20z3 cams
type s Oil pump
"cold air intake"
Re: Basemap for k24a7, k20a2 head and z3 cams
Posted: Fri Jun 09, 2023 9:38 pm
by CalibratEd
Have you tried starting with a stock k20 calibration file?
I can help dial in a basemap to make sure its running safe.
I also offer etuning services if needed.
-Ed
Posted: Tue Dec 12, 2023 5:57 am
by hondaboy0220
This isn’t much to the topic of discussion, but I was thinking of installing a K20A2 head on my K24Z7 for higher RPM output, but what I need to know is 1) how do I tune it correctly so that my car will still run? (2) with just my K24Z7 right now, all I have is a SRI, an exhaust, and a stage 2 clutch with a lightened flywheel; how can I increase my horse power more than where I’m currently standing (215HP)?
Posted: Sat Apr 06, 2024 3:46 pm
by kringles
for higher rpm id suggest you upgrade your pump first before swapping your head, but for tuning i cant imagine it would be any different you're just adding vtec to another cam increasing exhaust flow right?
Posted: Mon Apr 08, 2024 4:51 am
by hondaboy0220
I think so? See, the K24Z7 is different from other K24’s (e.g. the K24A2). The Z7 has a single square exhaust output whereas the A2’s and etc have the average 4 hole ports which is what Z7’s aren’t to optimal at making power. Can’t exhaust/exhale as much as a K20 and or other 24’s. How would I tune for an A2 head?
