2010 civic type r 410 injector base map
Posted: Mon Aug 22, 2022 2:19 am
by micky.dawson
hi all new to all this ive been and purchased the rdx 410 injectors with flash pro from tegiwa. now im stuck on what i need to do with getting them to work where do i get a download from to get thisto run its a standard car and i wanna keep it standard. only reason we have changed to bigger injectors is honda cant get them anymore
any help would be fantastic
cheers
Re: 2010 civic type r 410 injector base map
Posted: Mon Aug 22, 2022 10:16 am
You must set the correct injectors and dead times in the calibration and then may need to tune it on the dyno to fine tune the AF ratio.
Posted: Tue Aug 23, 2022 12:59 am
by micky.dawson
where do i find the dead times from never used this equipment before. im assuming once i plug in and go to hiondata vaults you find the base maps
Posted: Tue Aug 23, 2022 8:54 am
New calibrations can be opened by clicking on the New Calibration button. Go to the fuel section of the calibration window once a calibration is opened.
The dead times for the injectors should be provided by the manufacturer. Make sure the injectors are genuine as the fake ones cause problems for most people.
