Launch Control RPM not being set
Posted: Thu Aug 18, 2022 10:13 am
by rollin71
I have a 2013 civic si with Flashpro and I wanted to raise the launch RPM from 3500 to 5500. I have set the rpm in the calibration and I am using the newest firmware and software. I have saved multiple times while editing the calibration and its saved fine. The config also uploaded to the flashpro without any issues. I upload the config in my car and the launch RPM is still set to 3500. Any help would be appreciated.
Re: Launch Control RPM not being set
Posted: Thu Aug 18, 2022 10:21 am
Post the calibration as well as a datalog showing the issue.
Posted: Mon Aug 22, 2022 10:05 am
by rollin71
Here is the calibration file. I will do a quick datalog and post that next
Posted: Mon Aug 22, 2022 10:23 am
by rollin71
Here is the datalog file. Let me know if you need anything further.
Posted: Mon Aug 22, 2022 11:22 am
Does your cruise control work as it should?
Posted: Mon Aug 22, 2022 12:01 pm
by rollin71
Yes it does
Posted: Mon Aug 22, 2022 4:09 pm
Have you tried adjusting it as it says in the help file:
https://www.hondata.com/help/flashpro/l ... sub=launch
Posted: Tue Sep 06, 2022 6:43 am
by rollin71
I don't know if it had to do with the fact that the cruise control was accidentally on but after I uploaded the calibration and disconnected the battery everything worked as expected. Once I reconnected the battery and went out on a test drive the launch control rpm was set properly. Thank you again for the help.
