Software Tables For electronic wastegate control
Posted: Thu Aug 18, 2022 9:06 am
Hello my name is John and I am the owner of Fk8 Tuning and Development. I am messaging here because Doug suggested that this would be a more direct way of contacting the software team.
I currently have the 2018 Civic Type R that just made 757whp. However due to the nature of the hood exit exhaust the g30-900 tends to respond faster than the electronic wastegate can while running less that 28 PSI. If you could be so kind as to look into these software tables that would be greatly appreciated.
Civic Type R 2017-2018 years
1. Wastegate PID (This was I can better control turbocharger boost pressure on ported cylinder heads and smaller quick spooling turbos)
2. Is it possible to eliminate the electronic wastegate so more turbocharger options can be used? The ability to use other styles of wastegate will greatly open turbocharger possibilities.
3.Is it possible to add a single wire as an output on the ecu to control a 3 port solenoid. This way. the ecu can still control boost pressure using duty cycle.
If needed I will test these tables in order to confirm function.
On a separate request. Is there any information that is available on using a Quafe sequential while running Hondata. I am trying to verify how to properly create the ignition cut on upshift. I know that the Spoon Sports car used a Quafe Sequential and was running Hondata Software.
Thank you sincerely
John Pierro
Thank you sincerely
John Pierro
