Kpro v4 PND
Posted: Sat Aug 13, 2022 6:57 pm
by meech511117
I an having trouble with my ecu again!! I just purchased a used PND ecu with kpro v4 installed, plug it in load my tune and car fires up for a little running rough and slowly got worse and worse. I even got codes p1361 and po344, and originally thought my cam sensors got mixed up, tried switching them nothing, then I slowly started to realize more were not reading like tps, map ect. Car is turboed and is k24 and has a trc wire tuck harness that is brand new. More back story on ecu, I plugged it into the computer and it just flashes the red light. any ideas?
Re: Kpro v4 PND
Posted: Mon Aug 15, 2022 9:57 am
Have you tried the ECU in a known working vehicle?
What is the serial number that is on the K-Pro board inside the ECU?
Re: Kpro v4 PND
Posted: Wed Mar 01, 2023 11:00 pm
by Defcom012
I seem to be having the same problem as well. I have a PND ecu too. And the car starts up, but idles very low. Cyclinder 4 does not seem to be firing at all. Check all my grounds. Bought a new tuck harness, I even swapped the crank sensor wires around and still. Replaced my injectors with oem ones brand new. I also tried swapping the coil packs around, that cylinder just ain’t getting no signal to injector or is very low in voltage.
Re: Kpro v4 PND
Posted: Thu Mar 02, 2023 10:05 am
Have you tried the ECU on a known working vehicle?
