Firing out of order
1320vickers
Firing out of order
Post by 1320vickers »
S300v3
55489
Crx b20vtec
P28
Car was running fine now when I tyen the key on it fires and pushes the pistons down when there's leftover fuel.anytime I turn the pump on it cranks fine until it fires and then it starts backfiring and barley completes that Revolution and the sync light stops flashing until I stop and start cranking again
Re: Firing out of order
Post your calibration and a datalog showing the issue.
1320vickers
This is what I have for some reason my coils swelled in the middle
What do you mean when you say they swelled in the middle?
1320vickers
All did this
As those are not OEM, my guess is that they are faulty and most likely the cause of the issues.
1320vickers
They worked for a year but now u have oem rsx ones in and there doing the same thing just less of a backfire
Are you using resistor or non-resistor type spark plugs?
1320vickers
I use ngk bkr7e it says there resistor
1320vickers
I'm not sure if it matters but with dizzy out when I first turn the key to on I get a spark and as soon as I let off cranking I get a spark and coils are still getting hot
What has changed since it was working normally?
