I need a base tune for K24A4 (RAA-8) Head
Posted: Tue Aug 09, 2022 11:53 am
by hamadata
Hey everyone, I bought a car with a K24A4 swapped from a CRV and I just need a base tune to get me going as I am not thinking about doing any mods for a good while. I can send any revisions but currently the car runs very rich since I had to put a K24A2 base tune to get it to start up. I searched around a lot yet did not see any map for the K24A4 swaps. Thank you so much for any help!
Re: I need a base tune for K24A4 (RAA-8) Head
Posted: Tue Aug 09, 2022 1:28 pm
by hamadata
I was able to put a random K24 map on it which got it rolling, in the datalog I have a 3rd gear WOT pull and some regular driving. Thank you all!
Posted: Tue Aug 09, 2022 11:45 pm
by hamadata
Sorry about multiple replies as I keep remembering/learning about the different info you might need to help me. Here is the current tune flashed on my ECU
Posted: Fri Aug 12, 2022 1:55 pm
by hamadata
Alright, I Have made a few tweaks and these are the base calibration and the datalog of its idle to go along with it. Once again I am running the Stock K24A4 engine with the RAA head and no upgrades other than that. Please let me know what I should do next.
I had to compress the datalog in order to be able to upload it, if you need the uncompressed version please let me know.
Posted: Sat Aug 20, 2022 5:30 pm
by CalibratEd
Create a normal driving log. Make sure to let the car reach operating temperature before you start the datalog.
-Ed
Posted: Mon Aug 22, 2022 9:12 am
by hamadata
Here is a short datalog of it idling, the idle is pretty rough and its running extremely lean so I did not want to run it for longer than couple minutes. The car was up to temps when this datalog was logged. Let me know what you need next.
Posted: Mon Aug 22, 2022 9:40 am
by hamadata
From the map you sent me, I increased fuel until the AFR was within workable parameters. Here is your base map with added fuel and a datalog to go with it. Just as an option so that we are a bit closer to working condition. Let me know what you think.
Posted: Tue Aug 30, 2022 1:41 pm
by hamadata
Hey CalibratEd,
I was just wondering if we are still working on this tune. I see it’s been downloaded couple times.
Posted: Sun Sep 04, 2022 9:13 pm
by CalibratEd
hamadata wrote: Tue Aug 30, 2022 1:41 pm Hey CalibratEd,
Sorry for the delay I haven been swamped lately. The high number of downloads means other users have been downloading your files.
Load the new file and create a normal driving log. It seems to be running lean so I added fuel where needed.
-Ed
Posted: Sun Sep 11, 2022 12:21 pm
by hamadata
Here is the datalog to the revision you sent, It put the rev limiter at 3k after a bit of driving.
Posted: Thu Sep 15, 2022 6:41 pm
by CalibratEd
I cleaned up some of the fuel. I don't see why it would have a limit at 3000rpm. Has it had this issue with other calibration files? Is the car throwing any codes? Have you double checked your grounds?
-Ed
