k20z4 calibrations from vault dont load
Posted: Mon Aug 08, 2022 4:15 pm
by dylangelaan
Hi,
i just got an flashpro, i plan to load the fn2romaine map because i have the same setup, Gruppe m intake and stock otherwise. But all k20z4 calibrations from vault dont load except for 1 called pops and bangs. Another few give errors, the files were corupt, but most of them just wont load. You only see the retrieve window for a second,. today i tried the beta version but it doesnt seem to fix it.
I did try the group n calibration and the 'FN2 type r factory from the 'new calibration' menu both give me knock. whats weird is that the factory map gave me like 10x more knock. Both had like 85% of the knock in cyl 3.. so now i putted my car back to the stock ecu, no knock whatsoever, think its just the tune
Hope to get the gruppe m map, should be a better starting point.
Re: k20z4 calibrations from vault dont load
Posted: Mon Aug 08, 2022 4:22 pm
If the calibrations that have been uploaded are corrupt, there is nothing we can do about that unless the person that uploaded it reuploads it.
Posted: Tue Aug 09, 2022 12:33 pm
by dylangelaan
hi,
thank you for your quick answer. What i said, only a few calibrations give an error message, only like 3 of them most of them wont load at all. Are these corupted to ? That means there are only 1 calibrations i can choose from the vault instead of the 16 listed. i bought the hondata because of the calibrations listed.. as a proffesional company its normal to do backups.. its called a vault right? What about the customers who put there calibration in the vault ? did they all lose there calibrations because of this corupted non backed up server? I hope this isnt the case.
Whatabout the factory calibration giving massive knock? this calibration should be almost the same as stock isnt it? with the standard ecu i have no knock at all.
i hope you guys can help, thank you in advance
