Flashpro not connecting to car
Angeldejesus65
Post by Angeldejesus65 »
All i get is a blinkng power and calibra light but no connect. Tried it all, conected to laptop the lights stay on. In the laptop when connected to the obd2, light stay on but no connection to ecu. Givs me voltage reading however says its not connected for vin or ecu... need helppppppppp!. Thank you. Send a couple of email but noticed with reading other users, this get a faster reply
Angeldejesus65
Re: Flashpro not connecting to car
This is the error... checked voltage on obd2 and its good so im not sure what is going on. It just does not connect to get vin, ecu to finish setting it up. Lights blink when connected to car unless its connected to laptop
Angeldejesus65
I had emailed all this info but just noticed that its best here also. 2006 Honda civic sedan lx
Angeldejesus65
ok. so i send the flashpro back and it came back... connected the flashpro and same issue.. blinks but does not connect to ecu/vin...connects to laptop but no car...
Angeldejesus65
Spunkster wrote: Mon Aug 08, 2022 10:09 am With everything plugged in and the ignition in the on position, go to the Help menu and click on “send feedback”. Include a detailed description of the issue.
It was tested here and was also tested in a vehicle and it was working. Please check the OBD2 diagnostic port in your vehicle to make sure there are no pins that are bent or pushed in.
Please also try connecting in into a similar Honda vehicle and see if it can see It connecting to the ECU. Do not lock it to this other vehicle.
Angeldejesus65
updates.. problem fixed with Hondata new update... all this time it was not my car and Thnk GOd i did not dismantle my whole electrical searching for an issue
