AFR goes crazy.
Posted: Wed Aug 03, 2022 12:21 pm
Hi,
I have a situation with my civic FA5 where the AFR goes crazy from time-to-time. This condition, generally appears after a pull. After I finish the pull and start cruising, the AFR start to become VERY rich (11.0:1 or lower).
I've tried:
S. Trims are +-5% before the problem appears
The O2 sensor have 2 years
Tried different MAPs and also tried MAF
Sent the injectors for a service to clean and replace the filters
I've tried a calibration from another FA5 that I tuned
This has happened like 4 times in a 2-year span and normally I need to start from scratch the calibration because even a base map don't work because is "too rich", so I begin to reduce the fuel numbers to a VERY low level until it become lean. From there, I start to increase the values until the ECU asimilates the numbers pero antes de que la ECU comience a comportarte correctamente, tengo que subir sobre 10 calibraciones.
The only thing I can think is the ECU due to the quantity of reflash I've made. I know that the ECU has a very high limit of times that it can be reflash and maybe this is the culprit. Any help?
I've tried:
