Page 1 of 2
2012 Si Sedan SRI tune
Posted: Sun Jul 31, 2022 7:39 pm
by Mrlong818
I just purchased a 2012 Si sedan that already has a DC sports short ram intake. I’ve read they are not the best at cooler IATs but it’s all I have for now. The car also has a DC sports muffler and tip on it. I think it’s otherwise stock. I just purchased a flashpro and have zero tuning experience with this software. Can anyone point me in the right direction to get a base map to start from? The rev hang is annoying for sure, but this car scoots!
Re: 2012 Si Sedan SRI tune
Posted: Wed Aug 03, 2022 9:28 am
by CalibratEd
Mrlong818 wrote: Sun Jul 31, 2022 7:39 pm
I may be able to help. Do yo know how to datalog? Do you plan to dyno tune or ETune the Car? What are your plans for the car?
-Ed
Posted: Wed Aug 03, 2022 10:20 am
by Mrlong818
I researched the data log process and took one yesterday. I will upload it today when I get home from work, once I figure out how to do that. The tune I uploaded to the car is Hondata MAF tune for 2012-2015 Si’s. The only change I made to it was unchecking the over run(rev hang) feature, and I left everything else as it was. There is a marked improvement in how the car feels but I do think it could be better. There was a little bog between 2-3k rpm’s.
Current mods on the car are the DC sports short ram intake, DC sports muffler and exhaust tip, buddy club short throw shifter with acuity cable bushing and shifter base bushings. Suspension setup is BC adjustable coil overs with swift springs front and rear. I do not plan to do any other mods to the car as it drives great and handles well.
Thank you so much for replying to my thread! I’ll post the data log ASAP!
Posted: Wed Aug 03, 2022 2:21 pm
by CalibratEd
Mrlong818 wrote: Wed Aug 03, 2022 10:20 am
Sounds good. Looks like all you need is some minor adjustments.
-Ed
Posted: Sat Aug 06, 2022 8:14 am
by Mrlong818
Forgive the delay, life has been happening a million miles an hour for me this past week. Below are two datalogs i took. the first one is just normal driving because i didn't know there was a wide open throttle requirement. so a few days later after researching, i took another with some normal driving, a wide open throttle pull in third gear, and another in fifth gear because i had read conflicting information and didn't know which was preferred. Thank you wholeheartedly for looking into my setup! Cheeers!
Posted: Sat Aug 06, 2022 11:50 am
by CalibratEd
Mrlong818 wrote: Sat Aug 06, 2022 8:14 am
Please post the tune file as well.
- Ed
Posted: Sat Aug 06, 2022 6:28 pm
by Mrlong818
Oh, sorry Ed. i didn't know that was required as well, but it makes sense to me now that it is. Complete tuning noobie here! Calibration is attached. Again, the only modification I made was removing the Rev Hang feature.
Cheers!
-Paige
Posted: Sun Aug 07, 2022 10:24 pm
by CalibratEd
Paige, No worries. I like to make sure i am using the same calibration file. I enabled the Map tables. Create a normal driving long.
-Ed
Posted: Mon Aug 08, 2022 5:34 pm
by Mrlong818
Ed,
I took a datalog of my 25min drive to work. Mostly highway, and I kept the driving to normal style without really hitting Vtec at all. Please let me know your thoughts on things. Note: I have 93 octane fuel with ethanol. The first two datalog files I sent you were with 90 octane no ethanol as I was running an experiment on which was better for the car. Not sure if any of that matters, but I plan to run 93 with ethanol from here on out. Also, I just got a nastygram from my computer saying the file is too large to add. I even tried to compress it into a zip file with no luck. Wamp wamp...I guess i'll have to take another one that's shorter.
Posted: Mon Aug 08, 2022 5:52 pm
by Mrlong818
Snagged a quick datalog that should be smaller in size this time. Thanks again for the help!
Posted: Mon Aug 08, 2022 10:34 pm
by CalibratEd
Mrlong818 wrote: Mon Aug 08, 2022 5:34 pm
Ed,
The higher the octane the better. No worries about the datalog. I know there is a way to cut it but I don't recall how to do it. I cleaned up some of the fuel and smoothed timing where knock was present. Create a normal driving log. If possible have the car engage vtec.
-Ed
Posted: Tue Aug 09, 2022 5:45 pm
by Mrlong818
I took two logs today for you Ed. One in the morning and one in the evening to show how the car performs in multiple driving styles.
thanks for having a look!
Posted: Fri Aug 19, 2022 12:51 pm
by Mrlong818
Ed, have you got any thoughts on the data log I posted. I noticed a bunch of KR but have no idea how to fix it or if it’s bad. Perhaps some race fuel added and a retake? I’m wondering if I’ve gotten some bad fuel perhaps. I am running the 93 w/ethanol like we discussed
Posted: Sat Aug 20, 2022 5:04 pm
by CalibratEd
I cleaned up some of the fuel and removed timing where knock was present. Create a normal driving log.
-Ed
Posted: Sun Aug 21, 2022 6:03 pm
by Mrlong818
Thanks for the work Ed! I'll get this loaded and grab a data log tonight.
Cheers,
-Paige
