Fk8 Cruise Control not Working
Posted: Sun Jul 31, 2022 1:22 pm
by m_kluch
Im getting e-tuned by IMW. From the very first revision that Drob sent me I lost the ability to use cruise control. The cruise control can still arm and disarm (lights up grey) but it will not set and hold speed when I command it to do so (turn green). I have tried all gears as well as a wide speed range. I have Hondata TC enabled in the tune and that works as it should. I contacted Drob about it and he said he didnt turn off my cruise control and has zero ability to do so. Any advise would be helpful.
Re: Fk8 Cruise Control not Working
Posted: Mon Aug 01, 2022 7:55 am
What vehicle do you have? What ECU do you have?
Posted: Mon Aug 01, 2022 9:03 am
by m_kluch
2018 civic type-r with the factory ecu
Posted: Tue Aug 02, 2022 7:44 am
The next step would be to clear the error codes for all modules using the 'OBDII Diagnostics' windows then 'Diagnostics' tab.
Then post the calibration. If you do not wish to post the calibration here then email it to support@hondata.com
