16 cel all sensors
Briefx
16 cel all sensors
Post by Briefx »
I just did a b18a1 swap on my crx I loaded up the p74 calibration on my s300 and it will idle then whenever you use any throttle it won’t go and dies and I have 16 errors in smanager all sensors
Re: 16 cel all sensors
Is J12 cut on the ECU?
Who socketed this ECU?
Briefx
Post by Briefx »
21424 Is the serial
I don’t believe j4 is cut
I’m not sure who socketed it as I’m not the original owner
And the version is 2.7.8.0
Briefx
Post by Briefx »
It worked just fine with my b20 b3 that was in it
It also is flashing a red light I don’t have another vehicle sadly to test it with
I did not ask about J4.
Is J12 cut?
Briefx
Post by Briefx »
Sorry I just wasn’t thinking clearly lol j12 isn’t cut
It must be cut.
Briefx
Post by Briefx »
How do I go about cutting it just snipping one of the ends off? And I’m just curious how’d it work with my b20?
Yes just snip one end. Sometimes it works without it cut, but the instructions for socketing do include cutting or removing J12 as it is a must.
