D16z6 turbo
mzebley91
D16z6 turbo
Post by mzebley91 »
Completely stock engine, looking for a base map I can run to break everything in, I’m familiar with the program but have no tuning experience. If you have a base map I could start with I could set up my injectors/sensors and wideband for it. I’m also very mechanically inclined and know the basics I’ve learned from reading through the help section. I’m street tuning because that’s all I have funds for right now. Anything to start with would help tons.
If it helps, my wideband is aem, skunk2 4 bar map sensor and grams 550cc injectors
CalibratEd
Re: D16z6 turbo
Post by CalibratEd »
Are you able to provide datalogs with wideband data?
-Ed
Instagram: calibrated.tuning
mzebley91
Re: D16z6 turbo
Post by mzebley91 »
yes i am
CalibratEd
Re: D16z6 turbo
mzebley91 wrote: Sat Jul 30, 2022 5:30 pmyes i am
Ok, is there a tune you are currently running?
Do you have the data for the MAP sensor and the injectors you are running?
-Ed
mzebley91
Re: D16z6 turbo
Post by mzebley91 »
No there is not, currently I’m n/a on the stock engine. I do have that info as well. Would it be easier if I started with a street tune on the stock engine? I’m gunna run the turbo on the stock engine until I’m done rebuilding my other engine.
CalibratEd
Re: D16z6 turbo
It’s best to start with stock calibration that matches your engine and then modify it from there. Post the data for the map sensor and your injectors. I can work on a base map to get us started.
-Ed
mzebley91
Re: D16z6 turbo
Post by mzebley91 »
actually my head gasket blew before i even got to turbo it. R.I.P. so i am moving on to the built engine. thank you for your help anyways!
CalibratEd
Re: D16z6 turbo
mzebley91 wrote: Sat Aug 20, 2022 5:08 pm actually my head gasket blew before i even got to turbo it. R.I.P. so i am moving on to the built engine. thank you for your help anyways!
No problem.
-Ed
