Idle drops low
Posted: Tue Jun 28, 2022 12:58 pm
Hello Hondata,
I have an issue with FN2 I never had before with other Flashpro cars.
This is Euro FN2 K20Z4 with supercharger. The case is that when car is going to stop, clutch and brake pedal is pressed, the rpms goes very low, sometimes engine stops. The same happens on idle, rpms goes very low, when additionally brake pedal is pressed engine stops.
MAF sensor is discronnected, IAT plugged into intake manifold.
Map and logs attached.
Thank you,
Tomek
Thank you,
Tomek
