B18c base map help please
Posted: Sun May 29, 2022 11:50 pm
by 141202
So fresh built engine I can’t get it to start shoots flames and back fires a lot but no start. Can someone help make a map to get this car to start
-boost line rods
-diamond pistons
- la sleeves
- skunk 2 pro 1 cams. (Yes it’s degreed)
- COP
- victor X manifold
- fic 1100cc Injectors
- 72mm throttle body
- omni 4 bar map sensor
- borg s200sxe turbo 1.15 exhaust housing
Speed factory top mount manifold t4 divided 2 46mm waste gates
Any help getting this thing to start up would be great
Re: B18c base map help please
Posted: Thu Jun 02, 2022 1:57 pm
by CalibratEd
141202 wrote: Sun May 29, 2022 11:50 pm So fresh built engine I can’t get it to start shoots flames and back fires a lot but no start. Can someone help make a map to get this car to start
-boost line rods
-diamond pistons
- la sleeves
- COP
- victor X manifold
Can you provide datalogs with wideband data?
-Ed
Posted: Fri Jun 03, 2022 10:29 am
by 141202
I don’t even have a map I can drive it on. The map is dangerously lean. And the ignition timing is too high. I can handle messing with the fuel to dial it in. But idk what to do with the ignition timing.
Posted: Fri Jun 10, 2022 7:58 am
by CalibratEd
141202 wrote: Fri Jun 03, 2022 10:29 am I don’t even have a map I can drive it on. The map is dangerously lean. And the ignition timing is too high. I can handle messing with the fuel to dial it in. But idk what to do with the ignition timing.
I can work on a basemap to help get the car started but I need to know if you have a wideband. This will let me adjust the fuel.
-Ed
