K24 Ep3 basemap needed
dela4220
Post by dela4220 »
Hey all, looking for a baseman for a swap in an Ep3 following bolt on below, any help would be great, thanks in advance.
Jdm Rbb4 engine and head(stock cams and stock cam gear)
310 injectors
Type S oil pump
Rbc intake with 70mm throttle body
3" cold air intake(hybrid racing)
Plm tri y header
3" exhaust
6 speed gearbox(not sure if that matters)
CalibratEd
Re: K24 Ep3 basemap needed
Post by CalibratEd »
dela4220 wrote: Sun May 22, 2022 2:32 am Hey all, looking for a baseman for a swap in an Ep3 following bolt on below, any help would be great, thanks in advance.
310 injectors
Type S oil pump
Plm tri y header
3" exhaust
I may be able to help. Do you need something to get you to a tuner or do you need a Full ETune? Can you provide Datalogs with wideband Data?
-Ed
Instagram: calibrated.tuning
