2013 SI Flashpro tune
Posted: Thu May 19, 2022 7:11 am
by rollin71
I recently got the Flashpro and everything is up to date on the laptop with software and drivers. I was given a 2014 si basemap from EU but the gas in the EU is definitely a higher octane than here in the US. Since I have been running 100 octane in my us 2013 si.
I have another tune that I was given and it is supposed to be for 91/93 octane but the calibration is set to 2014-2015 si and if i select 2013 SI in the calibration section it states that it will change things with the tune or is that setting safe to change without causing any issues.
I appreciate any help because I am definitely new to this
Re: 2013 SI Flashpro tune
Posted: Thu May 19, 2022 9:34 am
European 2013 Civics are not supported by the software so there are calibrations available for them. I recommend using one of the built in calibrations that are found when you click on the New Calibration button.
Posted: Thu May 19, 2022 10:23 am
by rollin71
Well the tune that I have is for the 2014-2015 si and I was going to change the calibration to a 2013 SI. Does anyone know if this would cause critical issues?
Posted: Thu May 19, 2022 12:29 pm
You must choose the correct vehicle type from the New Calibration window and it will give you all calibrations that can then be used.
Posted: Thu May 19, 2022 7:54 pm
by rollin71
Will the calibrations affect the tune or is it just because its a different vehicle?
Posted: Fri May 20, 2022 9:05 am
If they are incompatible it will not allow you to upload.
