h22 euro R map
Posted: Thu May 12, 2022 2:22 pm
by HondaMat
Hi im looking for a h22 euro r base map or for bolt ons (i/h/e).
Re: h22 euro R map
Posted: Sun May 15, 2022 8:53 am
by G. Wiffington
Here you go.
H22 Euro-R in my 1993 Honda Accord on 93 pump.
Intake, header, 2.5 Yonaka Cat Back, No cat. Replaced h22 Euro -r injectors to stock 310cc injectors (used injector box) from an obd1 H22 so you may have to change the size because idk what the stock Euro-R size is.
Wideband: Connect to ECU Harness PIN: D10
VTEC Point: 4890
Rev Limit: 7800 (you can probably bump this up a little maybe 8200?)
That should be it about this tune, rips pretty good.
Re: h22 euro R map
Posted: Sun Aug 14, 2022 4:10 am
by HondaMat
G. Wiffington wrote: Sun May 15, 2022 8:53 am Here you go.
VTEC Point: 4890
Thx man! What TB where you using?
Re: h22 euro R map
Posted: Sat Oct 29, 2022 6:58 pm
by G. Wiffington
Stock H22 Euro-R Throttle Body was used.
Did you use the Map?
