UKDM PRA Civic Type R, Hondata app won't read boost pressure past 11.2 PSI
jw338
Post by jw338 »
Hoping someone has a solution to this issue. App works great apart from occasionally refusing to connect without app restart. The issue I'm having is that the boost pressure display reads perfect till it reaches 11.2 psi, then it pegs there till you let off. Kpro v4 logs are reading perfectly fine, boost on current setting peaks and holds at 15.2~ psi. Confirmed with a friend's external gauge temporarily plumbed into my car.
Any ideas how I can resolve this?
Thanks in advance
Re: UKDM PRA Civic Type R, Hondata app won't read boost pressure past 11.2 PSI
What MAP sensor are you using?
jw338
Post by jw338 »
It's a Hondata 4 Bar
jw338
Post by jw338 »
Has been selected as such in the map sensor drop down box
Post your calibration and a datalog showing the issue.
jw338
Post by jw338 »
I'll do so once I'm home with the laptop. Map sensor reads accurate with no issues on the logs. just stops reading at 11.2 PSI on the app. Even if you watch the live data on ''display'' tab in the laptop software while accelerating, it climbs past 11.2 psi to it's peak and the app follows along until this point. Very annoying, as the app is great otherwise!
jw338
Post by jw338 »
please find attached a datalog and calibration
What is the version of the app you are using?
jw338
Post by jw338 »
Version 1.6.9
What settings to you have set for that sensor in the app?
jw338
Post by jw338 »
Here, see attached
jw338
Post by jw338 »
Any ideas what the issue could be?
Is this the android or ios app?
jw338
Post by jw338 »
Android app
jw338
Post by jw338 »
Any further ideas on what I can try? I'd like to get this problem resolved.
Thank you
