Fan always on with ignition
Posted: Sat Apr 30, 2022 9:10 am
by ClassicAnomaly
Good morning! I am dealing with an issue where my fan comes on immediately when the car is on and stays on the whole time. I tried changed my radiator forced on settings and nothing corrects this. Not sure what else to look for. Fan switch is completely disconnected also. It seems like the "fan control" wire is permanently grounded somehow since it does it even if I jump the wire directly from the ECU connector.
Re: Fan always on with ignition
Posted: Sat Apr 30, 2022 3:48 pm
by ClassicAnomaly
I may have figured it out! Ordering a replacement relay now! Swapping engines and doing custom things to a car can definitely lead you down a path where things just aren't compatible or working the way you originally planned!
