Brand new kswap PLEASE HELP
Posted: Sat Apr 30, 2022 8:47 am
by P1500
I have finally finished my almost stock k24a1 swap but the person who was supposed to tune it kinda screwed me so now I am attempting to do a drivable tune myself, or get an e tune. All I’m looking for is a safe tune to drive on. It’s a k24a1 from an early (‘04) crv, rsx intake and tb, 650cc injectors, on kpro4. I seem to be having a problem with my o2 sensor not reading at all at the moment. Any tips/help/insight would be greatly appreciated, I can provide data logs and any other info needed.
Re: Brand new kswap PLEASE HELP
Posted: Mon May 02, 2022 6:30 am
by CalibratEd
P1500 wrote: Sat Apr 30, 2022 8:47 am
I can assist in providing you with a full ETune or get you running well enough to get you to a tuner. Let me know which option you would like. To be better assisted by me or anyone else on the forum. Post the current calibration file and datalogs.
-Ed
Posted: Mon May 02, 2022 9:01 am
by P1500
Attached is my current calibration and a datalog from idling, It wants to bounce up and down in rpm's but when I got the car back it was running at 19 afr. I have figured out how to calibrate my plx wideband and I have been able to get the afr lower. I also have an IAAV delete and an IACV delete in the mail, I believe those to be the issues with the idle. I'm running no A/C, and no power steering. I also mistyped my injector size, they are 550cc grams standard injectors. I won't be able to upload or provide any more datalogs until the 13th but I should have both deletes by then.
Posted: Thu May 05, 2022 6:56 pm
by CalibratEd
P1500 wrote: Mon May 02, 2022 9:01 am
Double check that you do not have any vacuum leaks before you adjust the tune. You will be chasing your tail with the tune if you have a mechanical issue. Also, double check that your vehicle speed sensor is working.
-Ed
Posted: Fri May 06, 2022 4:35 am
by P1500
I am using a gps speedometer for this swap, and a Miata transmission since it’s rwd. Does hondata absolutely need to have the speed sensor? A vacuum leak sounds plausible and that’s why I’m figuring it to be the iacv or iaav
Posted: Fri May 06, 2022 8:31 pm
by CalibratEd
P1500 wrote: Fri May 06, 2022 4:35 am
It is recommended by Hondata to run a VSS but you can runt the car without it. You will loose the ability to use launch control and per gear fuel and ignition compensation. I tuned a K swapped Datsun with no VSS without any issues.
-Ed
