Code 11?
Sokoto
Code 11?
Post by Sokoto »
My dash flashes a code 11 with the ignition in the on position. It shows no check engine light while running. Smanager shows no Codes whatsoever. I run Open Loop, and my AEM/Bosch wideband was showing AF ratios in the 8s at idle. Which leads me to believe I have a code 11 condition that I can't seem to verify or clear inside of the Smanager. Solutions?
Sokoto
Re: Code 11?
Post by Sokoto »
No need for a reply. I used the "clear DTC" option under the online tab. Also my O2 sensor is toast.
