new mapp required 410cc injectors and more
B0BSK1
Post by B0BSK1 »
hi ladies and gents been enjoying trawling through the froum o much talent on here and really looing forward to dialing i some sweet settings. already amazed with flat foot shifting and launch lol. just an old kid kidding on hes a young kid again lol
my current mods
tegwia induction
skunk 2 inlet
fd2 balance shaft delete
421 japspeed single exit
i had in vein tried my own mapping skills but soon ran out of talent as after installing my mods it ran cough cough rough
so i saw one on the forum created by EFICU
IvanJohn.SD.Rev01.6 (Blended)(Vtec4600).fpcal
this transformed my ride tremendously ovs i understand its not perfect for my car but certainly improved no end. after speaking briefly with eficu i know what needs to be done
will be installing my injectors this week when harness arrives and im aware i need to have the map etc changed to suit the new spray pattern
so reaching out to the main man himself eficu to see if you could hook me up with a starting point to go forward with injectors and little more please
cheers bob
EFICU
Re: new mapp required 410cc injectors and more
Post by EFICU »
Hi Bob,
So what year is your car and everything? What octane fuel are you running?
Let me know so I can get everything together to start you on.
B0BSK1
Post by B0BSK1 »
Hi bud oh yeah that info would help lol
I run 99 ron super unleaded allways find she runs sweeter
I'm an early 2007 gt fn2 type r
Just had valve clearances and timing chain full service all belts plugs etc so she's in good order if not high on the miles 160k
EFICU
Post by EFICU »
Sounds good. When are you installing the injectors? Let me know and I will get the first file put together for you.
B0BSK1
Post by B0BSK1 »
Hi mate thanks. Yeah I have the injector's and loom ready to go as of this moring . So when ever you can hook me up with the tweaks would be awsome bud
EFICU
Post by EFICU »
Sounds good. Here is the first calibration to get started. I don't know if we discussed it much, but we will want to go in and tune each cam angle one by one, then blend out the tables using that data. This will probably take around ten revisions to get it dialed and build a tune designed for your car specifically. If you need it done sooner let me know, but this is the best way to do it. This first calibration will be running on the 0* cam angle with vtec at 4500. The 0* cam angle is rather boring, so don't get discouraged, it lays the foundation for everything we do moving forward.
Have you made any datalogs with the IvanJonn calibration you were running? If so, I would like to look it over to make sure there aren't any red flags or anything.
Were you wanting to run a different rev limit since you have the balance shaft delete, or are you good with it at 8600?
Anyways, here is the first one for you. It's set up for the RDXs, and I swapped the gear ratios to match your FN2. Be sure to upload this one before starting it with the RDXs installed.
BOBSK1.SD.Rev01 (0Cam)(Vtec4500).fpcal
B0BSK1
Post by B0BSK1 »
Smashing many thanks for this
I'm happy with doing the data logs how ever many it takes .
I saw your looking for town driving so I assume stay out of the high revs apart from the third gear pull to asses first of all
Will do install parts tonight and come back with my first log so we can start the process many thansk again
Can't ✋️
Cheers bob
B0BSK1
Post by B0BSK1 »
also i happy to take advice of rev limter and see where the car takes us
EFICU
Post by EFICU »
Sorry, I forgot to give you the datalog driving protocol. So yeah, shoot for stop and go driving if possible. Or at least vary the RPMs and do some shifting through the gears if you're out in the country. We get a lot more average data when you do that, when driving at steady speed and RPM it only populates a small number of cells. On the drive, also make one wide open throttle (WOT) pull in third gear from 2500-8600. That way we can see the part throttle fuel and WOT fuel.
If you're okay with the limiter at 8600 I would just leave it there. I was curious if you were wanting to rev to 9000 or so with the oil pump. It won't make power over 8200 or so, so anything above 8600 is just for fun.
B0BSK1
Post by B0BSK1 »
hey bud sorry for the Late reply got cALLED away for work last time for two months thank god lol
so im back with plenty time on my side know
so heRe is the DATA LOG i see what you mean about it being flat till we go down this road lol
hopefully did plenty stop and go and got a good 3rd gear pull pleanty countrie rounds round our way for some hoonin
look forward to mk2 will get out asap and datalog the crap out of it haha
EFICU
Post by EFICU »
Do you have any datalogs from the prior calibration? I see two pending codes in the system, so I'm trying to see if you had them before or if it's because of the 8th gen calibration.
B0BSK1
Post by B0BSK1 »
i have one still saved yeah have attached the file. sorry about the hoonin it lol sure i was trying some flat foot shifting lol
i think i know the code your are talking about evap cvs comes up . think this came up when i was running the preivous mapp as i had no warnimg lights prior. i plugged my code reader in to clear the codes and they come back again even with the new tune. is this something physical i need to soret or do you think its in the mapp
any and all help appreicated
cheers bon
B0BSK1
Post by B0BSK1 »
only other thing i could think of is i installed a oil catch can to collect anything from the pcv itself . i dont have a draw on the catch can could this be causing the fault??
EFICU
Post by EFICU »
Unfortunately I am not 100% sure as I've never tried to use an 8th gen cal on an FN2. It took the calibration obviously, but I don't know how compatible they are. Let's try an actual FN2 calibration and see if the codes appear. Don't do any wild driving. Let's make a normal datalog and see if the codes come back or not.
BOBSK1.SD.FN2Test.fpcal
B0BSK1
Post by B0BSK1 »
cheers my man hears the new datalog . no more codes haha so where on the right track . many thanks bud
