Upgrade from 255 Walboro to bigger?
G. Wiffington
Post by G. Wiffington »
Hey do you guys think I should upgrade from a 255 Walboro to a bigger pump to lower duty cycle? I have attached two datalogs.
I have the old fat body style RC 750cc's & the fuel pump is not relayed by the pump, so I am just using the stock wiring as of now. Would a relay setup at the pump help give more pressure?
I also have a JDM stock fuel rail so I used a longer, skinnier -4AN hose for the rail to stock fuel filter line. I was wondering if that is way too restrictive causing the duty to be higher.
I do have a stock fuel regulator & no fuel pressure sensor. I guess I should Install those? (fuel pressure gauge & adjustable regulator)
Setup is F22B non vtec stock head & bottom end, 98 EK hatch chassis.
Finally spun third pretty good on street tires Hankooks (9psi, 82% duty 13 degrees timing).
Re: Upgrade from 255 Walboro to bigger?
You need to see what the pressure is doing. You may need larger injectors. This is something you may want to discuss with your tuner.
G. Wiffington
I am my tuner in this case lol. Still learning for sure
Okay I will see what the fuel pressure is doing.
Thank you!
G. Wiffington
Okay update:
I have an adjustable fpr now installed & it is set at base 43psi. The duty cycle is a little lower about 82% for the same pull as I uploaded before.
Would 50psi base pressure on RC750's too high?
It is probably ok.
G. Wiffington
Thank you.
Raised the pressure a little more & looks like I definitely lower the duty cycle.
Here is another pull finally hitting 11lbs.
New wastegate with 7-8lbs spring, the old one had a rip in the diaphragm & the spring was only about 4lbs.
